Enables MAC address learning from the payload of IP ARP packets.
| request | Enables learning only for IP ARP request packets. |
| reply | Enables learning only for IP ARP reply packets. |
| both-request-and-reply | Enables learning for both request and reply packets. |
| vr_name | Specifies a virtual router. |
Disabled.
To view the configuration for this feature, use the following command: show iparp
The following command enables MAC address learning from the payload of reply IP ARP packets:
enable learning iparp reply sender-mac
This command was first available in ExtremeXOS 12.4.
